| I upgraded my fuel system a bit. The existing pump I was using good to 800bhp on EFI-FI cars, so I figured I better up it a bit. The new pump is good for 1100bhp on EFI-FI cars. I also am going to be adapting Ford injectors (much cheaper, $420 for 6) into either the lower plenum, or into my new single throttle body intake manifold. This fuel setup will pretty much just replace my stock fuel tank (in my old setup, i tapped out drain plug, which was not the safest thing, but worked well) with a 15 gallon RCI fuel cell that I am having modified to work better with my setup. It will also replace the feed line from the tank to the pump with -12AN instead of -10AN. (reason being the inlet side of new pump is bigger, -12AN) The rest will stay the same from the pump to the FPR. I'm waiting on the tank to be welded by my local TIG guy, then I can install it. I cut the spare tire sheetmetal out of the trunk area in order for the fuel cell to drop into the floor (will post install pics this weekend). Parts List: ======================================================= 1. Aeromotive Eliminator (1100bhp) pump 2. -12AN feed to pump 3. -10AN feed to FPR 4. RCI 15gallon cell w/ GM sender 5. Autometer Fuel level Gauge 6. Holley universal fuel rail 7. Domestic(ford) 160# (~1600cc)injectors. ======================================================= The old setup installed:
 New Parts:
 you can see here that I still need to have the rails machined for the injectors, and tapped for fittings.
More Good news to note: 1. Thanks to Captain Boost (bought KAZ's car) I now have a TT subframe. 2. Pulled out the NA subframe (subframe & 1pc driveshaft is in classies) 3. Pushed out the bushings on the TT subframe (waiting on SPL solid bushings then I will install. 4. HEADS ARE OFF TO SGP!!! can't wait for those 5. Car is completely stripped awaiting 10pt cage install 6. No more wings west kit, body is going back to *stock 7. Z32power.com is now alive and kicking. Looking for 600 RWHP+ members ( to learn more go here) Here is the car as it sits now:
 Install pics coming soon!
